02-10-2024
09:03
04:51
02-10-2024
09:03
04:51
Hi my Inspire HR has started to display a message' clock error go to the fitbit app and choose another' I have looked and can not see where i am suppose to go to, to change the clock. Does anyone have an idea?
Best Answer02-10-2024 11:02
02-10-2024 11:02
I have the same error. I've looked through all the clocks, both fitbit and non fitbit. None of them are compatible with my Inspire 2. How could fitbit not have a clock that works/is compatible with their product?
02-10-2024 12:03
02-10-2024 12:03
I can't even find the clocks , where are they on the app? I have had the fitbit since 2020 this error only appeared a few days ago. Web page not much help either
Best Answer02-13-2024 06:44
02-13-2024 06:44
Welcome to the forums @Andreavlewis @SunsetRunner.
Thank you for taking the time to share the details regarding the situation with your devices. Sorry to know the difficulty.
I'd suggest you restart your tracker by following these instructions. After this retry changing the clock face.
Best Answer02-14-2024 22:59
02-14-2024 22:59
I had the same problem too. I wonder if there was an update or something cause also my device is going dead real quick. Just a few hrs later and it's dead. I used to be able to go almost a week without charging so something is up.
02:52
09:22
ManuFitbit
02-15-2024
02:52
09:22
ManuFitbit
Thank you I tried the above and nothing happened. However whilst in the gym I tried to start monitoring an excerise and this wasn't working. I got a bit fed up and keep pressing the side button oand after 5 mins the clock is back to normal and it is now back to how it was just weird
Hi I have somehow managed to sort the clock out. I couldn't get the excerise part to work and keep pressing the side button for 5 minutes. Now the clock is back and everything looks OK. But I agree I have to charge mine every other day I do wonder if it is because my phone is linked to it for messages as well ie text, WhatsApp
