07-25-2021
10:16
07:24
JuanJoFitbit
07-25-2021
10:16
07:24
JuanJoFitbit
Inspire Hr not showing display it on but it not showing anything it black and the battery it full please help.
@Siyamncwanho Welcome to our Fitbit Community. I totally understand how you feel about the screen issue that your Inspire HR has experienced.
I'd like you to restart your Inspire HR as described in this help article. After this, monitor your Fitbit device and see if the display works properly.
Hope this helps.
07-26-2021
13:27
05:02
JuanJoFitbit
07-26-2021
13:27
05:02
JuanJoFitbit
Inspire HR not showing any display time or any foot steps nothing but the battery is ful.
Hi
it didn’t help but thanks for replying
Moderator edit: merged reply
Best AnswerHi @Siyamncwanho keep posting in this thread so we can keep all your posts in one area to better assist you. Did you do the restart of the device as suggested?
16:00
05:01
JuanJoFitbit
07-26-2021
16:00
05:01
JuanJoFitbit
Hi Juanjo, I am experiencing the same problem since yesterday. It happened all of a sudden with no warning nothing. My Fitbit started to buzz for about 3 minutes then went black! It’s fully charged but not syncing and not tracking anything. Yes I did try to restart 3 times to no avail… I have had this device for only 12 months, and it’s my 3rd one. It seems they are programmed to self destroy after about one year…
Hi Odyssey13, I am experiencing the same problem since yesterday. It happened all of a sudden with no warning nothing. My Fitbit started to buzz for about 3 minutes then went black! It’s fully charged but not syncing and not tracking anything. Yes I did try to restart 3 times to no avail… I have had this device for only 12 months, and it’s my 3rd one. It seems they are programmed to self destroy after about one year…
