08-02-2020
13:32
15:01
RicardoFitbit
08-02-2020
13:32
15:01
RicardoFitbit
Just set up my new inspire hr. Got to the part where it tells you to try it on. Then nothing but a straight thin white line across the black screen. Doesn't swipe. No click showing. Nothing!!!
Best Answer08-07-2020 23:08
08-07-2020 23:08
08-07-2020
15:01
10:46
08-07-2020
15:01
10:46
Hi @dianecarter14, welcome to the Community Forums!
Thanks for bringing this to our attention and for the details that were shared in your post. To fix this uncommon situation, I recommend you to restart your Inspire HR following the next steps:
Let me know if you have any additional questions.
Best Answer08-07-2020 22:16
08-07-2020 22:16
I have the same problem. I cannot reset. Nothing happens when I hold down the button. The fitbit is unresponsive to swiping, tapping or button pushing. It shows the charge level when I connect with usb and otherwise a horizontal white line. I have removed and added the device to my account 3 times. My account says it is synced. I am using windows 10.
08-07-2020 23:08
