08-14-2020
17:22
11:41
AlvaroFitbit
08-14-2020
17:22
11:41
AlvaroFitbit
I know how to set up my short cuts, and I know how to reset my inspire when the short cuts change back to the default. I want to know why the keep reverting to the defaults - I might be out and want to use my weight training short cut which has turned into pilates, and I can't reset it. I don't understand why the issue recurs.
11:44
09:35
08-19-2020
11:44
09:35
@Lidobeach Welcome to the Community.
Let me help you with your Inspire HR exercise shortcut resetting. Not sure why this may be happening but thank you for taking the time to troubleshoot it. Could it be that the app isn't saving the settings? Do you use multiple devices to sync your tracker? I suggest you log out from the app, restart your phone and log back in. You could try restarting your tracker again if you wish.
I look forward to your reply.
11:53
11:50
AlvaroFitbit
08-19-2020
11:53
11:50
AlvaroFitbit
I only use my one phone to sync.
Moderator Edit: Personal info removed
11:55
09:36
08-25-2020
11:55
09:36
@Lidobeach thank you for the update.
Try removing the Pilates option from the exercise list for your Inspire HR, save and sync and then try recording a new activity and see how it behaves. Also did you restart your tracker and tried the other suggestions in my previous post?
