04-04-2021 03:09
04-04-2021 03:09
I track on my inspire HR when I go for a run, it records as 3.2km on the watch. However, when I sync to my phone, it appears that GPS gets lost and the fitbit app states I ran 2.4km.
This happens quite frequently, and the map mainly shows the same area where the route appears to get lost, but sometimes it deletes different areas? When I run using different apps (e.g. mapmyrun) it records accurately and keeps that GPS.
It used to be accurate and sync the same, has stopped probably in the last 4-5 months or so.
Any ideas what is happening? If it helps, I have a Huawei p20 lite.
Thank you!
Best Answer04-16-2021 08:58
04-16-2021 08:58
Welcome to the Fitbit Community, @Ellie-Hello. Thanks for sharing your GPS inquiry and for letting us know your phone's model.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time.
To learn more, see GPS.gov.
You can check help article: How do I use GPS on my Fitbit device?
Keep on visiting the forums.
