10-29-2019
03:37
05:24
AlvaroFitbit
10-29-2019
03:37
05:24
AlvaroFitbit
I’ve been having a problem with my Fitbit syncing to my iPod and after reading up on it found that it says having another Bluetooth device might cause issues. I do have another’s Bluetooth device in my phone but I found out that even if it’s not turned on it seems to stop my Fitbit from syncing. So ever time I haven’t to remove the other device, sync the Fitbit then repair the other device and I have to say it’s getting supper old.
05:43
13:43
10-30-2019
05:43
13:43
@SolusUmbra I hope you are doing fine.
Let me help syncing your Inspire HR. You can try the following:
Let me know how it goes.
Best Answer10-30-2019 05:46 - edited 10-30-2019 05:47
I have tried all the suggestions, the problem is I have to remove all devices every time I want to sync the Fitbit, then I have to reconnect all the other devices all over again. It’s ridiculous!! It doesn’t even matter if the other devices are turned on or off if they are listed the Fitbit won’t sync.
