08-22-2019
04:46
17:26
SilviaFitbit
08-22-2019
04:46
17:26
SilviaFitbit
Hi I had an Alta and my night time sleep was not tracking even restarted it several times. So I got an in inspire hr still night time sleep is not being tracked correctly. it seems like if I get up to use the restroom tracking turns off.
Welcome to the Community @nannyly. Thanks for the details mentioned and the troubleshooting tried.
Sorry for the delayed reply. I would like you to restart your Inspire HR and make sure you're not wearing it too loose. Please change the setting to sensitive and wear it again at night.
Best AnswerIt is in sensitive it is not loose. Example Sunday sleep log 3:03 to 4:25. Then 7:46 to 10:24. I was in bed entire time 3 am to 10:24 with 1 bathroom trip in there somewhere. So why no log 4:25 to 7:46
Thank you for getting back @nannyly. Sorry for the delayed reply.
Thanks for the details mentioned. We’re aware of it and are working to identify a resolution as quickly as possible. We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Let me know if there's anything we can do to assist you in the meantime.
Thanks for the details mentioned @Crotts and @Relly61. Sorry for the delayed reply.
I'am glad to hear that changing the sensitivity worked for you @Crotts.
Welcome to the Community @Relly61. Please try restarting his Inspire HR and advise him to try wearing his tracker not to loose to make sure it tracks sleep properly. Also, you can change the sensitivity.
Let me know how it goes.
Best AnswerWe have restarted the Fitbit. We have tried it on sensitivity and being able to place a finger between the band and the wrist...then changed the sensitivity to normal and having the band at the same fitting.
We then tightened the band up a notch, and having the sensitivity switched between normal and sensitive.
We have the sleep times set to 11:00 PM bedtime and wake up at 8:00 AM. Regardless, the app tells us that he goes to sleep after 2:00 AM....the other night it said it was 5:00 AM. We just want it to work properly...not interested in having to wake it up manually, or having to manually adjust the sleep times. It is getting very frustrating. I have a versa and have never had a problem.
Make it work!
Thanks for getting back @Relly61. I appreciate the details mentioned and the troubleshooting tried.
Your feedback and comments are appreciated, we're always striving to improve our services and trackers. We’re aware of it and are working to identify a resolution as quickly as possible. We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
