Had the inspire HR since early June, bought it off Amazon since it was cheaper than on the site. For the past couple days, it won't automatically sync and will sometimes say "device not found" when I refresh on the app. It won't read me any text notifications and it won't read my steps, it will track my heartbeat though. I did a soft reboot and then a full reboot, I even unpaired it and then repaired it to my Google pixel 2. I even turn off my Bluetooth and exit out of the app. That won't work or it will barely work. I've also tried deleting the app and reinstalling the app but that will give the same effect as turning the Bluetooth on and off. Any suggestions on how to fix it? I did email Fitbit support but wanted to see if there was anything I could incase I don't hear back for a while.
Hi @Emma_Bean nice to see you here. Thanks for sharing the Bluetooth issues with your Inspire HR. You've done an excellent job troubleshooting you Fitbit.
I really appreciate the time you've taken to get in touch with our support team, I'm sure they will contact you back soon. In the meantime, you can check the following steps to troubleshoot this:
Requirements for a successful synchronization:
If the syncing issue remains, I would recommend following the steps below:
You will find more syncing steps here.
This should solve any syncing issue that you're having, please keep me posted on the resolution! ![]()
