09-10-2020 14:15
09-10-2020 14:15
I was wondering why my battery died so quick in the past 2 days... Turns out it's bugging out and thinks I'm tapping/activating the screen when I'm really not. Im not a big fan of this update and it seems to be causing others issues as well. I know it's not an issue with the app and with the device update specifically because my tracker has been working fine perfectly before.
Please help me fix this situation 😭
Best Answer09-11-2020 17:07
09-11-2020 17:07
when you updated it may have changed your wake screen options. i would try pressing and holding the side button and double checking your screen wake light bulb icon has a line through it. doing this will cause the fitbit to only activate when you tap or hit the side button
