Inspire HR verification code issues
I woke up one morning and noticed my FitBit wasn’t syncing. I tried all the suggestions: turn Bluetooth off/on, force start on the FitBit while it is powering. Finally, I uninstalled and then reinstalled the app. Now, when I get to inputting the 4 digit verification code, although I am inputting the correct code (had someone else verify it was the right code) it tells me it isn’t the right code.
Moderator edit: clarified subject.
3 REPLIES 3
Welcome to the forums @WickedPickle
Thank you for providing the details regarding the difficulty that you are experiencing with Inspire HR.
Please make sure that you are using the latest version of the Fitbit app: How do I use the Fitbit app?
In addition, confirm that your phone's software is up to date.
Try one more time following the tips listed here: How do I set up my Fitbit device?
Yea, well, I've tried all this and it didn't work. Thanks.
Thanks for the response @WickedPickle.
Thank you for confirming.
Please give a try one more time following these points listed below:
  1. Turn off Bluetooth on your phone; wait 10 seconds, and then turn it back on.
  2. Try setting up your device again.
  3. Turn your Fitbit device off and back on. See How do I restart my Fitbit device?
  4. Turn your phone off and back on.
  5. Try setting up your device again. If you have trouble connecting your watch to Wi-Fi, see Why won't my Fitbit watch connect to Wi-Fi?
  6. Try setting up your device again.
  7. Remove all other Fitbit devices from your Fitbit account. For instructions, see How do I set up my Fitbit device?
  8. Remove your Fitbit device from the list of connected Bluetooth devices on your phone or tablet:
  • On your phone, tap Settings > Bluetooth.
  • Tap the information icon or gear icon next to the name of your Fitbit device.
  • Find the option to forget the device.
  1. Try setting up your device again.
  2. Uninstall and reinstall the Fitbit app. Note: Before you uninstall the app, verify that your phone is running a supported version of Android OS. If your phone is on an older version, you won’t be able to reinstall the app. For OS requirements, see Fitbit-compatible devices.
  3. If you still can't set up your device, please contact Customer Support .
