04-07-2019 19:18
04-07-2019 19:18
I have spent all day trying to get mine to connect. I have uninstalled the Fitbit app twice and have deleted all other Bluetooth devices that were connected to my phone and it still will not connect. I have an LG V10 and I have had multiple fitbits, it shouldn't be this hard. The Fitbit device does not seem to have a reset button. Any ideas?
Best Answer04-07-2019 21:12
04-07-2019 21:12
Hi @Preshus Here is the link to show you how to restart your tracker. You use the button on the side of the Inspire HR while the tracker is charging.
Helen | Western Australia
Best Answer04-08-2019 06:25
04-08-2019 06:25
You're not the only one. It must have taken me at least a dozen attempts. My Samsung 8+ found the Inspire HR but the 'connecting' would go around and around forever and never finish. I like you uninstalled and installed the app several times. Then turned BT on/off several times. Then reset the Inspire HR several times. Then I checked my BT setting on the phone. Double check those. I think the glitch in mine was I didn't want it to 'appear' when others were searching for a BT device or something. Good luck ....... it will happen.
