I have been having issues since June where the steps are recorded on the device but it will not sync to the app.
I have restarted the fitbit (factory reset), uninstalled and reinstalled the app (android, version 10), turned Bluetooth on and off, tried it with and without the Fitbit on its charger... It always gets to the same point. It detects the Fitbit, I get the 4 digit code which I put in, and then it goes through the motions but never connects. This is extremely frustrating...
Can someone please tell me how to get this to work properly.
09:23
11:47
07-10-2021
09:23
11:47
@Blackat84 Welcome to our Fitbit Community. I totally understand how you feel about the syncing issue that your Inspire HR has experienced. By the way, thank you for trying to get this issue resolved before contacting our forums.
Since the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
Best AnswerBeen having this issue myself my Inspire is now 12hrs and 20 mins slow!! Tried everything they recommend on the help section and nothing is working. Praying someone can tell me how to fix this problem because I use it to monitor my workouts etc
Best AnswerMore often than not, sync issues occur when fitbit device is talking on Bluetooth to multiple receivers namely phone/s computers etc having your fitbit app and device synced currently/earlier. Try turning off Bluetooth on those devices and sync initiates correctly on current device. Have a great weekend.
Best AnswerTried all the including syncing to another device and still not working. Everything it tells me plus other tips and tricks found amongst other threads and it STILL won't sync, in all for throwing in the towel and buying a cheap one off amazon
Best AnswerI gave up on Fitbit due to the many sync issues I encountered. I purchased a Xiaomi Mi Band 5 off Amazon, and it syncs perfectly with no problems. It syncs quickly and shows the sync progress clearly. I would never recommend a FitBit due to the poor sync function.
