07-07-2019 09:01
07-07-2019 09:01
My Blaze quit after 16 months very disappointing, $200 gone, so I punched the Inspire HR, same issues not enought accurate workouts to choose from, also when doing weights it counts about half the time so I'm still manually entering minutes. Disappointment.
Best Answer07-07-2019 15:06
07-07-2019 15:06
Are you using the mode called weights that is found on the tracker? This should record the whole period unless it is turned off early.
