05-19-2020 19:21
05-19-2020 19:21
Inspire has given me more issues than any other fitbits I have had - 6 issues (so far). 1. Band issues. 2. Not syncing. 3. Not swiping. 4. Unpaired from phone, with lost data. 5. Blank screen. 6. Split screen that quivers.
I have been a fitbit owner since 2011. I began with 2 or 3 Ulta's, then the One, and the Zip. I tried the Charge and the Flex for awhile, as well. May of 2019 I bought myself the Inspire. Loved it....at first.
1. About 4 months into the purchase, the band fell off. Turns out the device cracked where the pin from the band inserts. No force was being exerted on it at the time, nor ever, and I do not get the inspire wet or in contact with chemicals that could damage or weaken the product. I reported this to the company and they did replace it. The replacement, which is less than than 7 mths old, has now done the exact same thing!!! Looking at the Community I see others have had the same problem, too. This should not happen so soon and without good cause. (Design/manufacturing problem????)
2. I also have had issues with this particular model often not syncing, despite using ALL trouble shooting recommendations per fitbit website. On at least 3 different occasions, it just would not sync. Red exclamation point says "no device found". One of those times, it took 4 days and it finally sync'd on it's own. Unacceptable!
3. Another issue I have with this device is that occasionally I am unable to use the swipe function. For several days it would not swipe. I did a device reset (numerous times) and eventually one day, swiping feature was back, not sure why.
4. My 4th frustration with the Inspire was that one time it also unpaired with my phone. Not sure why on this, either. Nothing else on my phone unpaired, so it was specific to the Inspire. In this instance, I was able to re-pair the device, but did lose all the data from the unpaired time frame.
5. There are times when I have a blank screen. Nothing I do brings it back. I just have to wait it out.
6. Lastly, a brand new one, right out of the package, has a split screen that quivers and is unreadable. Functioning fine as far as syncing, pairing, charging. Restarting doesn't help, either. WOW! Unbelievable!
This is A LOT of trouble with one device in my book. I do not know what can be done for me, but hoping that by posting it, others can relate, add their issues, and that the company can be made aware.
05-19-2020 19:07
05-19-2020 19:07
My 3rd inspire. This one brand new, out of the package today and already misbehaving! Screen quivers and is split. Fully charged. Restarted before AND after pairing with phone, and adding it to my account.
Charging works, syncing works, pairing worked. Screen? DOES NOT WORK!
Best Answer07-20-2020 12:21
07-20-2020 12:21
I also have problems with the blank screen and lately being unable to swipe down. It has always taken a long time to connect and download info into the app on my iPad. The steps my fitbit records and the distance on my treadmill are way off. I calibrated my step length for set-up by walking across a room and counting my steps, measured the distance and divided it by the steps. Last night my fitbit was over a mile off from my treadmill???? I do put my fitbit in my pocket or on my shoelaces while walking since I play on my iPad and it does not record anything if it's on my wrist - same when shopping. Basically it's to remind me to get up and move but it doesn't always vibrate at 10 to the hour either - frustrating.....
Best Answer07-28-2020 12:16
07-28-2020 12:16
My Inspire will not pair, will not sync, will not keep correct time. When I try to pair it from my dashboard, Inspire is NOT one of the trackers listed. Needless to say the alta and any other will not work to pair
