12-18-2021
16:32
15:12
DavideFitbit
12-18-2021
16:32
15:12
DavideFitbit
I have an Inspire which was lost and then replaced ( by a sense). I have since found the Inspire which doesn’t charge. It simply ran out of battery and now won’t charge. I would naturally like to still use it as it’s not very old ( or at least has not been used)
12-20-2021 15:10 - edited 12-20-2021 15:11
Hi, welcome back to the Community forums, @Diana3.
Thank you for the information provided about the inconvenience you're experiencing with your Inspire.
Before considering other options, and if this is related to the battery, please make sure that you've followed the steps provided in this article. If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure described here.
Hope this helps, I'll be around.
12-24-2021
16:06
10:36
DavideFitbit
12-24-2021
16:06
10:36
DavideFitbit
I have tried everything. The inspire design for Charging is flawed in my opinion. The magnetic strip is weak and it always falls off the charger. We have tried everything. We also have two charge 4’s that the straps snapped off and broke the watch- we also have seen that there are many complaints about this issue. I have a new Versa ( 1 year) which is also not taking a charge sometimes. We will no longer be Fitbit customers after around 8/9 years that’s a real shame.
I hope this feedback helps.
Regards,
Best Answer12-28-2021 10:35
12-28-2021 10:35
@Diana3 Thank you for your reply and confirming that you already tried all the steps suggested earlier.
In this case, since you continue to experience the same inconvenience and the regarding the other problems you mentioned with the Charge 4 and Versa related to product damage, I recommend that you continue the assistance process with the Customer Support team so they can let you know how to proceed or what options are available for you.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a good day
