03-26-2019 05:15
03-26-2019 05:15
Hi - I have been using my new Inspire for a few weeks now but it is not measuring distance accurately. The number of steps are correct and I have changed my stride length in settings but it still appears to be using a default stride length to calculate distance (67.1 cm regardless of what I actually put in the stride length)
Any ideas?
03-26-2019 05:54
03-26-2019 05:54
Are you taking into account the different stride lengths for walking and running?
Best Answer03-26-2019 06:00
03-26-2019 06:00
04-01-2019 00:54
04-01-2019 00:54
Having the exact same problem. Moved from a Zip where distance was calculated correctly. Since I started using the Inspire, distance seems to be using a stride length of 67.1 cms.
I’ve asked Fitbit for a solution
Best Answer04-01-2019 01:21
04-01-2019 01:21
06-10-2019 10:29
06-10-2019 10:29
If you uninstall the app and reset fo you lose your history?
Comparing Fitbit distances with mapmywalk, a 3 mile walk only registers on Fitbit as just over 2.
Best Answer06-10-2019 10:45
06-10-2019 10:45
@SueR81 wrote:If you uninstall the app and reset fo you lose your history?
Once you have done a sync, all your data is stored in the Fitbit database by your account/email. As long as you log into the same account, nothing is going to disturb your historical data.
Best Answer06-10-2019 11:01
06-10-2019 11:01
