02-25-2021
11:11
09:59
AlejandraFitbit
02-25-2021
11:11
09:59
AlejandraFitbit
Since being a premium member my Inspire has being messing up. It was all OK until then. I have done only 8135 steps and my data shows 35000 steps. Anyone else had this problem? How can I reset or sort it?
02-26-2021
10:00
04:47
02-26-2021
10:00
04:47
It's great to see you around, @Vikings15.
For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Have a good day!
