05-28-2020
18:21
11:21
AlvaroFitbit
05-28-2020
18:21
11:21
AlvaroFitbit
I have only had my inspire for two days and I have gone from felling excited to disappointed. The tracker is for my steps, calories burned, etc. is incorrect I have reset, uninstalled, cleared data, syncing, turned off bluetooth and turned it back on, contacted support and it is still not resolved. I am ready to return this to the store tomorrow. Does anyone have any other ideas? By the way I am using an android.
Thanks in advance for your suggestions!
06-02-2020
12:12
05:52
06-02-2020
12:12
05:52
@SunsetRunner Thanks for stopping by!
Let me help you with your incorrect steps and thank you for troubleshooting this issue. What is the issue exactly? could you elaborate on this? Do you have more or less steps than you should? The more I know about this the better I will be able to assist you.
I look forward to your reply.
Best AnswerMy inspire calculated exactly one half of my 4-mile walk can this be corrected or should I just delete the walk I want my goals to show correct accomplishment
