06-02-2020
09:44
11:21
AlejandraFitbit
06-02-2020
09:44
11:21
AlejandraFitbit
How do I fix this? I’ve reset and re-synced a number of times. I wear on my non-dominant right wrist.
06-03-2020 11:22
06-03-2020 11:22
Welcome to the Community, @Leelu310.
Thanks for troubleshooting this timezone issue. If your Fitbit isn't showing the correct time, I recommend changing the timezone to a completely different one, sync the device, put the correct time and sync again.
To change the time, follow the steps in the article: How do I change the time on my Fitbit device?. Also, make sure that the device you are using for this has the correct time.
Let me know how it goes. 🙂
