07-12-2023 12:45
07-12-2023 12:45
I have had the same clock face (simple cat face with time) on my Inspire HR forever. The other day, I was trying to charge the FitBit with a new charging cord and having a bit of trouble determining whether it was charging. While I was checking it (turning clock face on periodically), suddenly the clock face was overwritten with this instruction: “Go to FitBit App and try another clock”. At first, the message would not be there when I turned the face on; the next time it would be; then not the next. At some point, it became permanent.
I thought I could just reload the same clock face, but . . . .I don’t see it, just the “ant” face. What happened to the kitty face (or the dog or the other simple faces)? All I seem to be able to find are messy, busy looks or boring ones.
Is it something I did? I would like to just reload the face I originally selected and get rid of the overwriting. Is there a way to do that?
Best Answer07-13-2023 15:13
07-13-2023 15:13
Same happened. Think they discontinued the cat. I chose the raccoon. It's not you!
Best Answer07-14-2023 12:08
07-14-2023 12:08
Rats!! Glad to know it isn’t just me or maybe it’d have been better if it were—then maybe it could get reloaded. Lol
Racoon?? I’d chose that—-if I could find it. All I can find is an “Ant”, which doesn’t do much for me.
Best Answer07-14-2023 12:23
07-14-2023 12:23
Best Answer07-14-2023 18:08 - edited 07-14-2023 18:08
Hhmm, curious. Today I was able to access the options for Clock Faces and there were more like I was used to seeing. I switched to the Owl without a problem. But, then saw Kitty there as an option. So I switched (back) to Kitty. Now it is just fine as if nothing had ever happened. 🤷:female_sign:. Whatever! All’s good. Thanks for letting me know I wasn’t just totally inept. 😊
