Having many problems with my Fitbit inspire hr which I’m fed up with as it doesn’t work after trying many fixes.
Instead of offering help the mods delete my message?
Did they not send you a PM with a reason? They normally only remove a message if it is in breach of the community guidelines which you can read at https://community.fitbit.com/guidelines
Is the problem you are having something that we in the community may be able to help with?
Alternatively, have you tried contacting customer support: contact.fitbit.com ?
