I fully charged my Fitbit and when I went to put it back on I noticed that it wasn't flashing green and the screen just shows the time and date!
@Luckylarry54 A few things to try ... 1) try plugging the charger in a different usb/charging port. 2) Try a restart. If you haven’t restarted before, here are the instructions:
Let us know if either of those work for you!
Best AnswerI figured out what was wrong with my Fitbit on my own! All is good now, I accidentally shut some systems off and now after restarting the ones I turned off everything is fine! Thank you for your response!
