No green LED light. Fully charged
ANSWERED
Inspire2. Fully charged. Records steps but no heart rate. No LED green light.
1 BEST ANSWER
Accepted Solutions
@A85 and @AlexBC hello and welcome to the forum!
One feature of the Inspire 2 is that you have the option to wear it on your wrist or on a clip. If it is set to wear on a clip, the heart rate monitoring will be turned off and the green lights won't be on.
To check this, press and hold both buttons on the sides of the device. You'll get a list of settings. Swipe up until you get to the last one. It should say "On Wrist". If it says "On Clip", tap on that and change it to "On Wrist".
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
4 REPLIES 4
Got exactly the same here this weekend. No heart rate or sleep stats.
Brilliant. Now working.
Get Outlook for Android
Thank you so much! It really working! Pheww..thank God
