No longer functional Inspire 2
My Inspire 2 isn't inspiring me at the moment. It will instantly stop working, then I'll put it in the charger, only to use it say 100%. Then there is a DATE and TIME issue. In other words, my FitBit is not functional and unusable.
1 REPLY 1
Hi @CindyWH, thanks for stopping by, I hope you're doing well!
Could you please describe me how those issues you are mentioning that appear on your device, for me to be able to give you a more specific answer about the steps that might be helpful to improve your situation with your Inspire 2?
By now could you please check if your device is properly paired like indicated in this article: How do I set up my Fitbit device?
Also check if you have the latest version available like indicated here. Update your Fitbit device
