09-21-2019
06:28
13:41
KateFitbit
09-21-2019
06:28
13:41
KateFitbit
Ive had this for two weeks and love it, but hit some problems today.
I wanted to start the exercise mode before a bike ride and it only gave these options
Run
Pilates
Pilates
Pilates
Pilates
Pilates
How can I get the other exercises back?
moderator edit: title for clarity
17:26
09:57
10-24-2019
17:26
09:57
Hi everyone! Nice to see you all in the Community! Thank you for your comments and posts!
I'm glad to hear that for some of you the situation got solved.
Our team is aware of it and is working to identify a resolution as quickly as possible.
I apologize for any trouble caused .
We appreciate your patience and look forward to get you back on track.
In the meantime, please restart your Fitbit .
Please let me know if I can help you with something else.
Best AnswerI had that happen and was to get it back right by going into exercise shortcuts setup. I forget exactly what I did there - maybe delete the Pilates and add back what I wanted; might have even had to go through that a couple of times.
For the exercise shortcuts setup, see
How do I change or reorder the exercises in the Exercise app?
Others have had this issue, I suspect as an unintended side effect of some update.
Best AnswerI have done this but there is something strange happening, according to the app Pilates wasn't even on the watch!
It is only half syncing, it will, update steps and calories and sleep, but not exercise. So I need to look elsewhere. Thank you anyway!
Best AnswerI have exactly the same problem... I am trying all the steps but nothing... let me know if you find the solution
Best AnswerI had to go to online chat in the end, but it is fixed now.
The battery had got quite low, so I charged it right up and then reset the tracker. You put it on its charger and then hold down the button until a smiley face appears. It didn't correct itself straight away, but I looked again 5 minutes later and it was fine.
My charge 3 keeps reverting on exercise to Pilates Pilates, instead of the activities I have set up on it. I am then unable to sync to update the exercises I use. I have read up and been carrying out a hard restart which does resolve the issue, but only for about 24 hours when it happens again. Really fed up with this now. Is something I can do to sort this once and for all, or do I need to return my Fitbit as faulty?
Best AnswerThis is happening to me as well so I hope someone will respond to help!
17:26
09:57
10-24-2019
17:26
09:57
Best AnswerAfter the IOS 13 upgrade, weights no longer appear as an exercise option. Instead, I have running, swimming, biking, Pilates, Pilates, and Pilates. Anyone else experience this issue?
13:50
09:57
10-30-2019
13:50
09:57
Hi @Mclifford34 , a warm welcome to the Community! Thank you for your post. It was moved here, to keep the Community in order and because here we are discussing the situation with Pilates.
Please have a look at my post above! I'll be informing you all if I receive new information.
Let me know if you have further questions.
Best AnswerWhen I go to the exercises on screen the ‘walk’ ‘treadmill’ and ‘weights’ options have disappeared and been replaced with 3 Pilates options!! Anyone else had this or know how to fix? Thanks.
Best AnswerMy fitbit has always allowed me to choose an exercise mode(run, treadmill, swim, elliptical, weights etc). Today it won't let me choose anything but run or Pilates
Best AnswerThis has now happened to me a 4th time in 2 months on my Inspire HR. It is getting really old to have to reset the Fitbit and it isn't always convenient to reset it so I'm not able to use the exercise shortcuts.
Can't we get a better fix?
Best Answerthe exercise shortcut seems to have defaulted to run pilates pilates pilates pilates even though i have different ones set up on the app. what ca n be done to fix this?
Best AnswerThat happened to me, too: 3 Pilates! Tech support helped but here I am with 3 Pilates and not the exercises that I do. It was complex, what the support guy did, so I won’t explain. It took a few tries, too.
Best AnswerHi, I’ve got the same problem and have seen that most people posted this issue last year, has there still been no fix for it then?
also I was unable to restart my Fitbit inspire hr using the method described so what do I do next to resolve the Pilates issue?
Best Answer100%same problem. Pilates Pilates Pilates. I've reset. It's 100% charged. Looks like this is a known Fitbit inspire hr issue they just don't care
