07-03-2022
23:04
22:19
07-03-2022
23:04
22:19
07-04-2022 04:23
07-04-2022 04:23
@mavalgreb There is a notification you can set to get a push notification for your Step Goal Milestones. Tap on your profile image, then scroll down to Notifications. This page lets you set your account push and email notifications. (These are Account Settings and stay on your account if you switch devices.) There is a push notification option for a step goal milestone that will tell you 75%, 100%, or 125% of your goal.
Also, there is a special goal celebration on your mobile app screen if you meet all your goals that day.
Laurie | Maryland
07-04-2022 03:40
07-04-2022 03:40
Hi, @mavalgreb , your Fitbit will only celebrate your primary goal, although you can see in your app your progress on all your goals. With many of the clock faces can also check this info on your wrist by tapping to change the displayed stat. You might enjoy the “stats heavy” clock face which will show you how you are doing on several measures
Your Fitbit will also not alert you at points along the way to your goal, although you can, of course see your information on your wrist or in the app. The app has circles which become solid as you make progress toward your goal.
I hope this helps. Welcome to the forums!
07-04-2022 04:23
07-04-2022 04:23
Laurie | Maryland
