I’m getting additional text on my Fitbit screen, instructing me to go to the app to fix the clock. As far as I can see there is nothing wrong with the app 😞
I also have an issue trying to change the strap, the small metal lever isn’t there so I can’t remove the wristband on one side. Tried a pin / needle unsuccessfully.
Any help would be appreciated, thanks
Best AnswerHello @Jen28H
It sounds like your Inspire HR is stuck on an error giving you this odd message. Try restarting your Inspire 2 and that should fix the issue.
Heres how: Just place your Inspire HR into its charger then press and hold down the button on your Fitbit until you see a small smiley face then release the button. You should feel the Fitbit vibrate letting you know the restart is complete.
‘About your wrist band…
🤔 I wonder if your small metal lever got hidden under the band. This is something I’ve never dealt with so I decided to dig around a bit to see what I could find. I did find this thread with individuals experiencing the same issue and some are saying success using different tactics. Maybe you might find one that will work for you here: https://community.fitbit.com/t5/Other-Versa-Smartwatches/Pin-inside-Fitbit-Versa-band-broke-off/td-p...
😃 I hope this provides you with the answer you were seeking and helps fix the issues you are experiencing. Please let me know
