I was/am having syncing issue with my Pixel 2 and following the advice on several other threads I went into my bluetooth settings and "forgot this device". I would like to try to re-pair and see if it is better now, but for the life of me can't figure out how except to remove the Inspire HR from my fitbit app and set it up again. Is this the correct process?
Best AnswerHi @VilleGirl No, dont remove it. Just go into the app and manually sync your tracker (go to the Inspire HR - tap the little tracker picture in the top right corner - and tap sync). That will re-pair it to your phone. Please come back if you continue to have problems.
Helen | Western Australia
I have the same problem. WHAT TRACKER picture in the corner? I am on the app and I went to Inspire HR and it shows a tracker which says last time synced. Nothing happens when I click it.
