Hi, how do I set up a replacement device? It’s exactly the same model, an Inspire HR.
Thank you
In the app on your phone, go into your profile settings by selecting your profile image at the top left of the dashboard. Then select "set up a device". When you choose Inspire HR it will ask if you want to replace your existing tracker. Just say yes and follow the prompts. All your data, badges, settings etc will be retained.
