08-07-2020 08:31
08-07-2020 08:31
The restoration chart in the sleep module is not populating. It looks the the app is calculating the percentages but the chart is blank. The other two charts (hours asleep/awake & sleep cycle) are populating fine. I’m using an Apple IPad 4 And I have a Fitbit InspireHR I purchased in Dec 2019.
Best Answer08-09-2020 08:25
08-09-2020 08:25
I think you are correct as there are no sleep stats this morning. I hope it gets fixed soon as that is one of the reasons I upgraded to Fitbit Premium.
08-08-2020 11:13
08-08-2020 11:13
I think this may be related to the new wrist band I put on that is still stiff. I put the band on one notch tighter last night and now the graph is populating but I have an impression on my wrist from the Fitbit InspireHR. I ordered new bands from Amazon and hopefully they will be more flexible so I don’t have to wear the Fitbit so tight at night.
Best Answer08-09-2020 05:06
08-09-2020 05:06
Hello @K1Ward and welcome to the Help forums. Many users are experiencing an issue with the sleeping heart rate graph. It is most likely an app bug and isn't related to your new wrist band.
Fitbit is aware.
Laurie | Maryland
08-09-2020 08:25
08-09-2020 08:25
08-10-2020 02:05
08-10-2020 02:05
This is exactly what happened to me. It happened this morning after I installed the latest Fitbit app Update, from the App Store to my Iphone 6S. Now ALL the sleeping heart rate data in the Restoration stage of sleep has disappeared since I bought the Inspire HR in May. Help, Fitbit!!
08-13-2020 05:42
08-13-2020 05:42
I am having the same issue with Charge 3 watch. Hoping it is app issue
Best Answer08-13-2020 05:43
08-13-2020 05:43
I am having same issue. Using Charge 3 with premium. Restoration chart not working for last 4-5 days
Best Answer08-14-2020 02:51
08-14-2020 02:51
I have the same wristband and the restoration chart is not populating either 😞
Best Answer08-14-2020 06:19
08-14-2020 06:19
Best Answer08-14-2020 06:30
08-14-2020 06:30
Ah, good - an upgrade to the Inspire HR? or a software update? Did you have to talk to them on the phone?
Best Answer08-14-2020 06:43
08-14-2020 06:43
08-18-2020 01:39
08-18-2020 01:39
Happening to me too. Inspire HR. I know that it is logging my heart rate overnight because I can view the graph in the HR tab. Just that this info is is not also being graphed in the sleep > restoration tab.
Using iPhone 8 and Inspire HR.
Best Answer08-18-2020 05:53
08-18-2020 05:53
Best Answer08-18-2020 05:56
08-18-2020 05:56
Best Answer08-18-2020 17:05
08-18-2020 17:05
I’ve updated the app and updated the Inspire to version 1.88. The sleep restoration graph is still not populating.
Best Answer08-19-2020 00:26
08-19-2020 00:26
Thanks Hoops, helpful info. Hopefully they'll come out with a proper solution soon. F x
Best Answer08-27-2020 04:45
08-27-2020 04:45
Same problem here.
Best Answer08-27-2020 05:21
08-27-2020 05:21
Hi there
my restoration sleep chart graph was back this morning. It’s been off about two weeks. During this time fit bit has had an update along with latest Apple iOS. Glad it’s back. Good luck folks
Sue
Best Answer08-27-2020 05:50
08-27-2020 05:50
Same problem for me on IPhone 11 app
Best Answer08-27-2020 05:57
08-27-2020 05:57
