03-27-2020
18:00
16:30
03-27-2020
18:00
16:30
I have an Inspire HR which I got a couple of months ago.
It no longer shows the sleep tracking module on my
dashboard and also refuses to connect with my internet.
I have searched in the community for answers but find
nothing that helps. All my other devices connect with
my internet which is AT&T. I have tried resetting the fitbit
and also checked that it has access to location.
Best Answer03-31-2020 18:22
03-31-2020 18:22
@mgdie213 Check to make sure the sleep option is selected to show in the app dashboard. Select “Edit” in the top corner - if Sleep isn’t listed in the “Manage Today Items” then scroll to the bottom and hit Discover and select “Health and Fitness Stats” and checkmark Sleep.
Best Answer03-31-2020 18:36
03-31-2020 18:36
Thanks so much for your reply. I tried the steps you gave me but when I go to Discover the message says that my device has no internet connection. All my other devices connect to my internet, but this one. I have tried resetting my fitbit, but it still won't connect. It did in the beginning, but then after several weeks dropped the connection and my sleep module disappeared. Very frustrating 😤.
Best Answer04-25-2020 08:37
04-25-2020 08:37
Hi
Did you get to the bottom of this issue as I have the same problem. Getting to the stage where I could throw the bloody thing out the window!
Best Answer04-25-2020 12:27
04-25-2020 12:27
Best Answer04-25-2020 13:36
04-25-2020 13:36
Best Answer04-25-2020 19:22
04-25-2020 19:22
