10-02-2022
16:50
21:04
10-02-2022
16:50
21:04
New to this device. What does the initial screen indicate? I can't find it anywhere in the manual. It has date and step tally and in-between those are large numbers i.e. 07/50, I am sure I will feel like an idiot when someone tells me. Thanks in advance.
Hello @SunsetRunner
Those large numbers you are seeing is the time. So basically your Inspire 2 is telling you that it’s 7:50.
If seeing the time in that manner isn’t your cup of tea you can certainly change your clock face into something you might like better.
Here’s how:
Open your Fitbit App and tap your profile picture in the upper left. Now scroll down and tap Inspire 2 then tap gallery. Next tap the clocks tab. Browse the available clock faces. Tap a clock face to see a detailed view. Once you have found the clock face you like tap Install to add the clock face to Inspire 2.
Once your finished just remember to sync your Inspire 2 so that your Inspire 2 will accept the changes if you made any.
😃 I hope this provides you with the best answer to your question. Please come back and let me know if this helps.
Thank you for answering this poor souls question. Much appreciate you taking the time. I’m ashamed I didn’t figure it out myself.
😃 Not a problem @SunsetRunner! I’m happy I could help. Being new to Fitbit (or any other fitness tracker) can be sort of overwhelming at first. I’m sure you’ll get the hang of it in no time. The community is here to help no matter the question.
Here is a link to the online Inspire 2 manual: https://help.fitbit.com/manuals/manual_inspire_2_en_US.pdf. If might be useful in the future and it gives you a deeper look into the different things you can do with your Fitbit.
‘Please consider marking my previous response to you as “best answer”. It will help others with the same question find the answer quickly. I’d appreciate it. Enjoy the rest of your day and as always Happy Stepping!
