09-13-2019 14:14
09-13-2019 14:14
Sleep score isn’t showing up. It’s tracking the length of time I’m sleeping. It’s tracked my score before but it doesn’t work consistently. How do I fix this?
Best Answer09-13-2019 16:02
09-13-2019 16:51
09-13-2019 16:51
Same on mine. Last time it showed was Wednesday
Best Answer09-26-2019 00:16
09-26-2019 00:16
09-29-2019 04:25
09-29-2019 04:25
Same with me. It’s always been inconsistent, works for a few days then stops but I haven’t had a sleep score for a week now. It’s very irritating!
09-29-2019 04:45
09-29-2019 04:45
I'm pretty new here. I have my Fitbit since Friday...
One night I got a sleepreport but no sleepscore. I think it has tot do that the Fitbit missed my heartrate for a short time during the night.
I strapped the Fitbit a little better, and last night I had a sleep report and a sleepscore aswell. I hope this is a fix...
09-30-2019 10:47
09-30-2019 10:47
I bought the Inspire HR a month ago per my strength and conditioning coach's insistence. After a month of wearing it religiously, I only have two Sleep Scores with Sleep Stages. My trainer is frustrated with it and wants me to buy the new Versa 2. His Versa is generates Sleep Score and Stages every night. Maybe it's a component quality issue? I've tried it tight, loose, two fingers from wrist joint, etc. I do get the sleep pattern every night and heart rate works fine.
10-04-2019 23:20
10-04-2019 23:20
Me too. Score shows sometimes, all other sleep info fine.
10-05-2019 12:41
10-05-2019 12:41
Hi...did you ever get a fix as to why your sleep score won’t show up..thanks
Best Answer10-05-2019 15:13
10-05-2019 15:13
Hi
No - but I’ve stopped using the “Begin sleep now” function and since then I’ve had a sleep score.
Dont know if it’s co-incidence but it’s worked for the last 4 days ...
Bev
10-05-2019 19:11
10-05-2019 19:11
I just got my inspire hr yesterday. For last night’s sleep i got sleep stages but no sleep score. I also noticed that in my settings page i could only turn on “receive sleep insights” but there was no option for sleep score... is this normal?
10-05-2019 23:56
10-05-2019 23:56
@Mustlovecats
I think you have to give it some time/days for the Sleep score to show up. Maybe till the end of next day or more (1-2 days). I bought my Inspire HR on the evening of the 23rd of September and I got a sleep score only from 25 September morning onward.
I also don't think there is a settings option regarding sleep score.
Best Answer10-06-2019 00:14
10-06-2019 00:14
10-22-2019 17:54
10-22-2019 17:54
Charge hr is not showing the sleep score either.
Best Answer10-23-2019 00:25
10-23-2019 00:25
I'm wearing versa 2 and it only show 2 nights sleeping score after that... pooofff now its only showing sleeping pattern but no scores.
10-23-2019 00:50 - edited 10-23-2019 00:54
This has posted twice, and I can't find a way of deleting it, so see reply below which is the correct one.
Best Answer10-23-2019 00:51
10-23-2019 00:51
I've got an Inspire HR. Bizarrely, the sleep score shows on my phone, but not on my tablet or my desktop PC. Duh????
Best Answer10-28-2019 06:13
10-28-2019 06:13
Fitbit - any reply here? Mine is on and off constantly. Intermittent sleep scores yet nothing is being done any differently...
10-28-2019 09:13
10-28-2019 09:13
I've had my HR for two weeks and it's recorded my sleep patterns without any problems. There are two settings that may give your HR a more accurate Sleep Score. Both are under your Dashboard's, View Settings button. First, make sure your Wrist setting is on Non-Dominant. Second, set the Sleep Tracking to Sensitive. I do wear my device "snug" due to extremely hairy arms. Sometimes I question it's accuracy, but it's always recorded the different stages, time and produced a score. Good luck!
11-06-2019 14:54
11-06-2019 14:54
My sleep score shows up maybe once every two weeks. Very frustrating that it doesn't work....product issue and I liked the sleep data before the sleep score.
