Sleep chart changed?
ANSWERED
For the last few days, I can’t access the same kind of sleep chart that I had when I first got my Fitbit a couple of weeks ago. The original charts were rounded and showed REM sleep along with other helpful info. Now, I am seeing straight lines with much less information. Is there a way to get the old chart back? Did I change something by accident?
I use an IPhone XR for syncing if that makes a difference - and it’s up to date.
1 BEST ANSWER
Accepted Solutions
Some days, you just don't get sleep stages without knowing why.
But using "Begin sleep now." is a good way to make sure you never get sleep stages.
4 REPLIES 4
See Why don't I see sleep stages today?
Thanks for replying!
The chart that you posted is the same one that I am seeing... I do use the manual setting now  to track sleep although I had it on the auto setting AFTER the chart changed to see if that made a difference.
Everything else is as you suggested so I’m wondering if my device simply isn’t compatible with providing that type of chart any longer (perhaps since the latest update?)
Johnny Row - my apologies... I thought I was doing the auto sleep mode properly when I wasn’t. I called Fitbit about this and got the issue solved. Now I know not to set anything before I go to sleep and just let the bracelet do its own thing. It will generate the graph I am looking for that way.
Thanks so much for your help!
