07-24-2019 17:08
07-24-2019 17:08
My sleep icon has been greyed out for ages. On the PC and app I can get the stats, but not on the actual unit. The software updated a few days ago and that seems to have fixed the draining battery issue. Didn't fix the sleep icon though. Why it is always greyed out?
Thanks
Nanci
06:41
05:07
07-25-2019
06:41
05:07
@naniq, welcome to the Fitbit Community! It's great to have you here!
Let me help you with your sleep data on your Inspire HR. Try restarting your device and make sure it is syncing with your computer.
Let me know how it goes.
Best Answer07-25-2019 08:19
07-25-2019 08:19
Hi. There's no problem syncing with the computer. Not at home right now so I can't say at the moment if a re-start will work.
Best Answer07-25-2019 18:32
07-25-2019 18:32
@AlvaroFitbit wrote:@naniq, welcome to the Fitbit Community! It's great to have you here!
@AlvaroFitbit Reset, still greyed out,
Best Answer07-31-2019 17:17
07-31-2019 17:17
So I guess there's no solution?
Thanks
08-01-2019 05:34
08-01-2019 05:34
I have the same issue
