Hi,
I have a new Fitbit and wore it last night to try the sleep function. I manually started with sleep now. The graph indicates where I was awake and restless however it’s not tallied the minutes up in the summary (still shows 0x restless/awake despite coloured lines on graph), does anyone how why or how to fix? It is all up to date and I use an iPhone. Tried on and off/logging out/refreshing apps.
Thanks in advance - Zoe
01-28-2020
09:26
07:53
01-28-2020
09:26
07:53
@ZBEHR Welcome to the Fitbit Community! I hope you're doing well!
Thank you for reporting this issue and thank you for troubleshooting this issue. The team is aware and are looking for a way to correct this information. Have you tried checking this on the website at fitbit.com? Still I appreciate your patience while this is resolved.
I'll be around.
Best AnswerSleep tracking is a joke. Worse yet is calling fit bit support.
Mine will track nothing. If I tell it I am going to sleep, and then tell it I woke up it rarely works and misses hours of sleep. Went to sleep at 10, told it, the next day it started tracking at 2:30 AM.
Very frustrating.
