08-18-2022
15:15
21:04
08-18-2022
15:15
21:04
The sleep tracking on my Inspire 2 worked wonderfully, however, now it is not working, at all. Even when I manually turn it on, before bed, which I don't want to do. Has something changed? How can I get it working again?
08-23-2022 05:43
08-23-2022 05:43
Sleep not tracking since August 16th. What do I do? Tried resetting it til the smiley face appeared. Nothing.
Best Answer08-23-2022 09:11
08-23-2022 09:11
I've seen something similar. After a good first year of sleep tracking, it's been intermittent. Some nights are good, some nights claim I did not wear the device, some nights show only an hour or two of sleep (quiting at some point in the night).
I've reset the device, I'm wearing it snug, there is no low battery, I've set it to "low sensitivity". None of that appears to make a difference. I suppose it could be a device failure but it's working otherwise so I wonder if it's software-related.
15:42
04:12
YojanaFitbit
08-23-2022
15:42
04:12
YojanaFitbit
I used to have a sleep mode that I manually pressed once I was ready to sleep. That function is no longer available on my Inspire 2 since they sent me a replacement. Please help!
08-24-2022 05:17 - edited 08-24-2022 12:05
Hi everyone.
Welcome to the Community Forums.
Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out. Please confirm your Inspire 2 is not on clip mode by pressing and holding the button on your device, and tapping 'On Wrist' in case you need it. For more information, see How do I wear my Fitbit device?
With that in mind, I recommend considering the following in order to get sleep stages:
Hope this helps.
Best Answer08-24-2022 08:30
08-24-2022 08:30
Thank you Yojana. What's kind of weird with my situation is that it's not consistent. Some nights it works and I'm not doing anything different that I know of. This is my last week:
I know this doesn't give you much to work with, but it appears there's some threshold of sleep that my device is no longer recognizing. It may be a sensor or it may be a software update that's happened in the last month or so (when I started experiencing the problem). Maybe you can ask your software engineers if they've made any changes recently. 🙂
Best Answer08-24-2022 09:24
08-24-2022 09:24
I don't see the "on wrist" option on my device. How do I find it?
Best Answer08-24-2022 12:11 - edited 08-24-2022 12:13
@Bruce823 Thanks for sharing those details with us. Can you please confirm when this issue started?
@AASmith1975 You can find this information under "Inspire 2" > "Adjust Settings", here: How do I navigate my Fitbit device?
Hope this helps.
Best Answer08-24-2022 13:16
08-24-2022 13:16
@YojanaFitbit The first night I had an issue was July 10. Then July 14. Both of these times my night's sleep was broken into two according to the watch. At some point I tighted my watch band another notch but I've continued to have 2-4 issues a week since then, some of them (as shown by my graphic above) showing absolutely no sleep for the night.
