02-14-2020 04:13
02-14-2020 04:13
I just got a new inspire HR because I wasn’t getting text notifications on my Alta. Well I’m not getting them on the Inspire either. I have gone thru all the suggested fixes and it still won’t. So is there fix to this problem? If not, I will be returning this Inspire.
Best Answer02-14-2020 19:40
02-14-2020 19:40
Hi @loveRving What phone are you using? There are a few phone related notification problems at present.
Helen | Western Australia
Best Answer02-15-2020 06:09
02-15-2020 06:09
I’m having this same problem, it’s been going on since September, I could have returned the product then but was told by customer support they were working on a fix. I’m super irritated by this.
Best Answer02-15-2020 06:29
02-15-2020 06:29
@Al26exa What phone are you using? My issue (Samsung and Android 10) was been fixed in the latest update, so even if yours is a different phone they ARE actually working on it.
Best Answer02-15-2020 07:05
02-15-2020 07:05
That’s weird cause they told me via Twitter that they thought the troubleshooting they posted had fixed it which it didn’t. I’m using an iPhone 7
Best Answer02-15-2020 16:12
02-15-2020 16:12
If what they told you didnt fix it, Id suggest you go back to Support. Have you been through the process in the first post in THIS thread by KateFitbit. If done exactly as stated it should sort it out for you. I dont have an iPhone so cant test it.
