10-24-2019
19:14
13:16
YojanaFitbit
10-24-2019
19:14
13:16
YojanaFitbit
It says that it is compatible to receive text and call notifications but I am not receiving any on my inspire. I've done all the troubleshooting and checked all the boxes on my phone and app. Still nothing.
10-28-2019 04:30
10-28-2019 04:30
Hello thank you for your response. I ended up going to my profile pic and under the tab Devices selected the image of my device which took me to General Notifications options and there I selected which Notifications I want to receive. That solved my issue.
Best Answer10-25-2019 11:20 - edited 11-10-2019 19:23
Yeah same issue with my S10 too. Help is appreciated
Thanks in advance.
Regards,
Shane
___________________________________
Best Answer10-25-2019 13:14 - edited 10-25-2019 13:18
Welcome to the Community Forums @Beautisoul. Nice to see you here @ShaneP12. Thanks a million for the troubleshooting steps that you've tried to fix the notification issues with your Inspire.
Both of your Android devices are in the list of compatible devices, so please confirm the following information on your phone:
Then perform the recommended troubleshooting steps:
Notifications should work as expected after your device syncs. If they don't, continue with the next task:
If this isn't solving the issues with notifications, continue with the next steps:
As final step you can try the following:
Tell your phone to "forget" your device, removing the connection between the phone and the Fitbit device.
Please give it a try and keep me posted on the resolution.
Best Answer10-28-2019 04:30
10-28-2019 04:30
Best Answer10-28-2019 14:11
10-28-2019 14:11
Hi @Beautisoul thanks for letting me know that you're able to find the option to fix the notification issues with your Inspire!
You did a great job and I really appreciate you've marked your post as the best response of the thread, this might help other users having similar issues.
I'll be around in case that you need anything else.
