01-04-2020
06:27
06:24
LanuzaFitbit
01-04-2020
06:27
06:24
LanuzaFitbit
InspireHR (new for Christmas) SOMETIMES (50-50) tracks walks around a variable elevation trail for 2 miles as "elliptical" instead of "walk" - why? how do I fix?
App is on iPhone, mac air is reporting the elliptical.
Thanks! Rod
Best Answer01-20-2020 23:35
01-20-2020 23:35
Tap the exercise tile.
Tap the gear in top right
Set unwanted auto detected exercises to ignore.
01-04-2020 13:51
01-04-2020 13:51
I think your depending on the tracker to figure out what you are doing.
This requires your arms to move in a natural way, often not possible when hiking.
Have you thought about using the manual multi sport mode of walk or hike? This also can produce a map of you have your phone with you.
Why is it happening, it has to do with your arm movements.
Best Answer01-08-2020 04:57
01-08-2020 04:57
AN answer....but not solve the question. Thanks anyway
Best Answer01-20-2020 14:49
01-20-2020 14:49
Have you disabled elliptical?
01-20-2020 15:53
01-20-2020 15:53
I have NOT.......can you tell me how? APP, actual fitbit, or online account ? Sorry, pushing 75 years, struggling with tech! Thanks for your help
01-20-2020 23:35
01-21-2020 07:15
01-21-2020 07:15
Thanks Rich. I decided to just ignore it 'cause I know I'm walking not doing elliptical. I do appreciate your willingness to help the old guy
Best Answer01-21-2020 07:31
01-21-2020 07:31
Telling the watch to ignore any type of exercise that you do not do will make the watch screens more responsive since these settings control some of the background processing.
02-10-2020 12:04
02-10-2020 12:04
I've had my Inspire HR for 2 days, had a One for years. Both days, dashboard shows I spent ~30 minutes on elliptical, but I was walking on an even/flat surface (indoor track). I think deleting the exercise would take away all those steps, which I obviously don't want to do. How can an elliptical be mistaken for a flat track?
Best Answer02-10-2020 12:09
02-10-2020 12:09
Best Answer02-10-2020 12:19
02-10-2020 12:19
I'm fairly technically savvy, but I don't get these instructions. There is no "exercise tile" and don't see "auto detected exercises" anywhere.
Best Answer02-10-2020 12:30
02-10-2020 12:30
Best Answer02-10-2020 21:32
02-10-2020 21:32
@SunsetRunner tap on the exercise tile.
TaI the setting cog
Adjust your settings.
As for why a walk gets mis labeld, we would need to see more on your walk.
Best Answer08-20-2020 21:13
08-20-2020 21:13
I want to choose an elliptical with IFIT integration, budget about $ 600, which one should I choose? I was really confused after seeing this list https://www.bestforlives.com/best-elliptical-under-1000/
Best Answer08-21-2020 03:47
08-21-2020 03:47
I have no idea.......the original post was when fit bit aspire hr was brand new.....I just learned to ignore it .
Not at all techie, old man just needing to watch heart rate when I exercise.
