05-20-2019 17:54
05-20-2019 17:54
How do I make hot power yoga a recognized activity? After doing two 74 minute power classes my inspire only recognized 7 minutes of activity??????
05-20-2019 20:45
05-20-2019 20:45
Welcome to the forums!
I would set this up as one of the seven shortcuts you can have on your device. Its under settings. Yoga is pretty low key and it will never recognize it
You can have up to 7 exercise shortcuts. On your dashboard click on the gear and choose settings. Look for exercise shortcuts. Change to what you want. Make one of these Yoga.
Device will need to sync before it takes place.
Then when doing scroll to the exercise tab and select yoga. Push in the button to start and when done push it in again to stop
Manual is here and will explain it
Versa Manual at top of page
Wendy | CA | Moto G6 Android
Best Answer05-21-2019 03:30
05-21-2019 03:30
@Ceejaytee Your tag says you are using the Inspire (not the Inspire HR). The advice given by @WendyB will not help you. The Inspire does not have the Exercise app that is on the Inspire HR.
If you have the Inspire, you will need to log your yoga classes manually. From the app dashboard, tap on the Exercise tile > tap on the stopwatch > set it to log > enter yoga then put in your start and stop times. You estimate your calorie burn. The only option is generic "yoga" and it does not give variations.
If you have the Inspire HR, then you can put it on the Exercise Shortcuts on the Exercise app. The Inspire HR uses your heart rate in its exercise algorithms to estimate calorie burn.
Active minutes are intensity related and you must do ten consecutive minutes before they start to count. The effort and intensity can change in yoga classes. Even with a heart rate based tracker, you might not get 74 active minutes in a 74 minute class.
Laurie | Maryland
Best Answer12-24-2020 09:09
12-24-2020 09:09
I am completely against yoga because it is very cool
