12-02-2022
16:46
20:58
12-02-2022
16:46
20:58
Until recently, I was able to toggle off the automated calories burned entered by Fitbit and manually enter calories burned by either a sliding bar or by direct entry. The toggle to do this is not grayed out and only get the automated calories burned. I typically check calories burned by heart rate and at times Fitbit is significantly lower with their auto-populated value. How can I get the manual entry toggle back?
12-05-2022 19:04
12-05-2022 19:04
I was just told by tech support that this feature went away with the upgrade but that I should suggest bringing it back here.
https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features).
Best Answer12-05-2022 21:05
12-05-2022 21:05
