Hello everyone.
This is my second Inspire HR (replaced because of a faulty one) and it just stopped working after going in the water. I can actually see the droplets of water inside it. Wasn't it supposed to be waterproof? I even tried leaving inside a bowl with rice and with salt to get the moisture out, but no way, it's still therw. Of course it won't turn on and when I put it to charge it heats up very quickly.
Any help will be appreciated!
Have a nice weekend.
Best AnswerHi @josias.italy usually a wet Fitbit is placed into dry rice for at least two days. Charging it while seeing visible water droplets isn't a good idea. You could fry the battery.
Best AnswerHi @Odyssey13 . Thanks for your reply.
The droplets disapeared and then I charged it. But I guess the heat from charging made the droplets come back.
Still not working!
Best AnswerIt's possible it may not return. You can always get with support to see what options, if any, are available.
https://myhelp.fitbit.com/s/support?language=en_US
