08-14-2019 05:42
08-14-2019 05:42
how do I change 24 to 12 house clock
08-14-2019 05:59
08-14-2019 05:59
You can choose between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync your fitbit will be updated.
NB some versa clockfaces override the profile settings. If this happens to you then there is usually a setting for the clockface.
08-14-2019 05:59
08-14-2019 05:59
08-14-2019 06:05
08-14-2019 06:05
Happy to help, @danbella. To change to a 12 hour clock, follow the directions below:
07-03-2020 10:44 - edited 07-03-2020 10:46
Thank you, thank you, thank you...all the other directions did not work. To Steve UK.
