You can choose between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync your fitbit will be updated.
NB some versa clockfaces override the profile settings. If this happens to you then there is usually a setting for the clockface.
Happy to help, @danbella. To change to a 12 hour clock, follow the directions below:
