12 hour clock
ANSWERED
how do I change 24 to 12 house clock
1 BEST ANSWER
Accepted Solutions
You can choose between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync your fitbit will be updated.
NB some versa clockfaces override the profile settings. If this happens to you then there is usually a setting for the clockface.
3 REPLIES 3
Happy to help, @danbella.  To change to a 12 hour clock, follow the directions below:
  1. From Fitbit.com click the gear icon —> Settings   Personal Info.
  2. Scroll down to Clock Display Time and select the time you want.
  3. Tap Submit and sync your device.
Thank you, thank you, thank you...all the other directions did not work.  To Steve UK.
