Hello @RhondaFleww and welcome to the Community. The Fitbit Weather app uses AccuWeather and should be preloaded on to your Versa 2. If it isn't on your device, please try the following:
- Tap on your Profile avatar, then your Versa 2 tile
- Tap on the Gallery icon
- Keep the toggle on Versa 2 and review your apps list
- If Weather isn't there, slide the toggle to Apps and tap on the Search icon (magnifying glass)
- Choose Weather (the Fitbit app) and install it
- Once you install it, there are both Settings and Permissions that you need to set to have it work.
Laurie | Maryland
