01-07-2021 08:36
01-07-2021 08:36
Hi believe my step count is not correct under counting did a 7 mile walk but only showing 5.67.miles ..
01-07-2021 09:55
01-07-2021 09:55
I am having the same problem. I am not sure how to fix this. Does anyone know?
Best Answer01-07-2021 10:33
01-07-2021 10:33
Same problem with my Versa 2. Annoying.
Best Answer01-08-2021 03:16
01-08-2021 03:16
Please don't say step count is incorrect, then tell use the distance is off.
Where you using GPS? Have you properly set your stride?
If you want to check the steps counted, then you need to do a step count.
I put the tracker on its manual walk tracking.
Start walking with my right foot, then count every left step.
Stop at 100, the tracker should be close to 200 steps.
