Hi,
I am using Fitbit Versa 2. I just realized and its happening for quite some time now that the watch and app has suddenly started Active minutes and has stopped recording Active zone minutes. It was easrlier recoding Active Zone minutes.
Am I the only one facing this issue or every one else has the same.
Fitbit switched from Active minutes to Active Zone minutes.
Many people prefer the former because if/when you don't get accurate heart rate readings the latter is pretty meaningless.
It also depends on which versions of things you are using whether it has changed.
