02-08-2020 18:30
02-08-2020 18:30
Why is it SO hard to switch out the versa bands??!
after an hour I finally removed a band. Now adding one is even worse. I can’t do it. I have read directions, watched videos, and I’m doing everything right. Is it defective?! It can’t be this hard....
02-08-2020 23:58
02-08-2020 23:58
I find the trick is the angle at which you put the band on. If I try and put it in so it’s level with my versa I can’t do it. If I do it with the band at a downwards angle (like how it sits on your wrist) it’s a lot easier.
